# Create request action
Use this action to create a request in a Workflow app.
# Input fields
Workflow app
Select a Workflow app in which to create a new request.
New request fields
Fill in the fields for the new request. The available fields are determined by the Workflow app you select.
# Additional input fields
Additional input fields are variable. They are determined by the Workflow app you select and the columns present in its corresponding data table.
Output is dynamic and may vary depending on the actions and triggers in your recipe, as well as the columns present in your Workflow app's corresponding data table.
To use this data in downstream steps, map in the relevant datapill from the datatree.
- Request
- This JSON object includes the following available attributes. Additional output is available depending on the Workflow app you select and its data table.
- Record ID
- Workato automatically generates a unique ID for each record in a Workflow app's corresponding data table.
- Active task
- A nested JSON object within the Request object.
- This object is empty if there is not an active task associated with the request.
Available attributes include
- Task ID:
- The ID of the task.
- Task name:
- The name of the task.
- Status:
- The task's status.
- Assigned user:
- A nested JSON object within the Assigned task object.
- This object is empty if the task is assigned to a group.
- User ID:
- The ID of the user assigned to the task.
- User name:
- The name of the user assigned to the task.
- Email:
- The email of the user assigned to the task.
- Status:
- The status of the user assigned to the task.
- Assigned group:
- This object is empty if the task is assigned to an individual user.
- User ID:
- User name:
- Status
- Due date:
- The due date of the task.
- Created by
- User ID:
- The ID of the user who created the request.
- User name:
- The name of the user who created the request.
- Email:
- The email of the user who created the request.
- Status:
- The status of the user.
- Groups
- A nested JSON object within the Created by object.
- Group ID:
- The ID of the group this task is assigned to.
- Group name:
- The name of the group this task is assigned to.
- List size
- List index
- Stage
- Stage ID:
- Group name:
- Created at
- The date the record was created.
- Updated at
- The date the record was most recently updated.
Last updated: 2/13/2024, 1:10:22 AM
