# Change workflow stage action
Change workflow stage is an action you can use to transition a request in a Workflow app through the workflow.
Typical use cases for this action include the following scenarios:
  • If the input provided does not pass validation, mark the request as Invalid.
  • If the request does not need user approval, mark it as Done automatically.
  • If the manager approval task is approved, mark the request as Completed.
# Input fields
  • Workflow app
  • Select an App from the list of available Apps.
  • Record ID
  • The ID of the record whose workflow stage you plan to change. You can map this in using a datapill from a trigger or action from the Table Storage or Workflow apps connector.
  • Workflow stage
  • The new workflow stage for the record. Select one of the stages defined in your application settings.
Last updated: 2/13/2024, 1:10:22 AM
