# Component properties
Customize page components using the properties panel. The properties panel provides options that enable you to create dynamic pages that change in response to user input. You must configure each property for each component on your page.
The following table provides a high-level overview of the different types of page properties and component compatibility. Each property has a unique set of configurable fields. Additionally, the set of available properties varies for each page component.
View our page components documentation for information on customizing properties for each type of page component.
Property | Description | Compatible components |
Editable | Determine whether page components are editable, read-only, or editable only under the conditions you specify. The editability of components affects what other properties are customizable. |
Appearance | Determine how components appear on the page. This includes deciding whether components are required, visible, assigning hints and placeholders to your components, and more. |
Data | Configure how your data tables appear on your pages. This includes choosing which columns appear on your page, filtering columns, and more. |
Options | Configure how choices components appear on your page by determining the source for multiple choice (dropdown) components. |
Validation | Determine accepted file types and maximum file sizes. |
Last updated: 2/13/2024, 1:10:22 AM
