# Configure the Workato On-prem Agent (OPA)
Configuring a Workato On-prem Agent (OPA) on the Sap server consists of the following steps:
- Download Workato On-prem Agent (OPA)
- Download the SAP JCO libraries
- Create SAP profile in OPA
- Run OPA
# Download Workato On-prem Agent (OPA)
For Workato to talk to SAP, you must install a Workato On-prem Agent (OPA) on your SAP server, or on a separate virtual machine that can reach your SAP server.
The Virtual Machine server and your SAP server must be in the same domain, not outside of the firewall, and able to access each other. To test the virtual machine server and the SAP's server's ability to communicate with each other, try to ping the other server from each server.
Follow these instructions to download and setup a Workato On-prem Group and subsequently following creating an On-prem Agent.
CONNECTION SETUP RECOMMENDATION
We recommend that you select Directly in Workato for easier connection management in the future. However, if you are using Secure Network Communication (SNC), you must select the Manually in each agent option.
# Download the SAP JCO libraries
If you do not already have a license to use SAP JCo libraries, contact your SAP provider for a license.
Visit SAP JCO Libraries (opens new window) to download the following items:
- SAP JCO connector libraries
- Direct connections (version 3.1.7 and above)
- Message server connections (version 3.1.7 and above)
OPERATING SYSTEM COMPATIBILITY
Select the correct version of the library for your operating system.
Additionally, refer to SAP Note 2786882 - SAP JCo 3.1 release and support strategy (opens new window) to make sure your operating system fulfills all prerequisites.
After you download the libraries, place them in the lib_ext/
directory of all On-prem Agents in your created group.
- Windows users:
- Ensure that you have imported all relevant files into the
lib_ext
folder. You should have imported a total of 3 files:sapjco3.dll
,sapjco3.jar
, andsapidoc3.jar
into yourlib_ext
folder. A file namedsap-connector-X.X.X.jar
should already be inside. - Mac users:
lib_ext
folder. You should have imported a total of 3 files:libsapjco3.dylib
,sapjco3.jar
, andsapidoc3.jar
into yourlib_ext
should already be inside. - Linux users:
lib_ext
folder. You should have imported a total of 3 files:libsapjco3.so
,sapjco3.jar
, andsapidoc3.jar
into yourlib_ext
# Run OPA
Follow these instructions to run the On-prem Agent. After it successfully runs, you can move on to configure the SAP connector in Workato.
# Create a SAP profile
- If you have chosen to setup connections
Directly in Workato
- Follow these instructions to create a SAP connection within Workato. - If you have chosen to setup connections
- Follow these instructions to create a SAP profile within the On-prem Agent. After configuring theconfig.yml
file, you must restart the On-prem Agent for the changes to be enforced. This update to theconfig.yml
must be done for every agent in your group.
FURTHER READING
To complete your connection to SAP RFC, read the following guides:
Last updated: 12/4/2023, 6:02:46 PM
