# New request trigger
This real-time trigger runs when there is a new request in a Workflow app.
This trigger also runs when a user creates a new record manually in a workflow app's corresponding data table.
# Input fields
  • Workflow app
  • Choose a Workflow app to check for new requests.
  • When first started this recipe should pick up events from
  • Get new requests since a particular date/time. Leave empty to get new requests since one hour ago. Once the recipe has been run or tested, you cannot change this value.
You can also toggle Set trigger condition to only process trigger events matching conditions you specify.
Output is dynamic and may vary depending on the actions and triggers in your recipe, as well as the columns present in your Workflow app's corresponding data table.
To use this data in downstream steps, map in the relevant datapill from the datatree.
Change ID
The ID number that corresponds to the Workflow app's corresponding data table.
Request
This JSON object includes the following available attributes. Additional output is available depending on the Workflow app you select and its data table.
Record ID
Workato automatically generates a unique ID for each record in a Workflow app's corresponding data table.
Active task
A nested JSON object within the Request object.
This object is empty if there is not an active task associated with the request.
Available attributes include
Task ID:
The ID of the task.
Task name:
The name of the task.
Status:
The task's status.
Assigned user:
A nested JSON object within the Assigned task object.
This object is empty if the task is assigned to a group.
User ID:
The ID of the user assigned to the task.
User name:
The name of the user assigned to the task.
Email:
The email of the user assigned to the task.
Status:
The status of the user assigned to the task.
Assigned group:
This object is empty if the task is assigned to an individual user.
User ID:
User name:
Email
Status
Due date:
The due date of the task.
Created by
User ID:
The ID of the user who created the request.
User name:
The name of the user who created the request.
Email:
The email of the user who created the request.
Status:
The status of the user.
Groups
A nested JSON object within the Created by object.
Group ID:
The ID of the group this task is assigned to.
Group name:
The name of the group this task is assigned to.
List size
List index
Stage
Stage ID:
Group name:
Created at
The date the record was created.
Updated at
The date the record was most recently updated.
Last updated: 2/13/2024, 1:10:22 AM
