# Setting up HashiCorp Vault secrets engines for workspaces
WARNING
Switching to workspace-specific secrets management causes all previously-configured external secret references to stop working.
# Prerequisites
To complete the steps in this guide, you must have the following:
In Workato:
- An account with the Data Monitoring/Advanced Security & Compliance add-on. For more information, contact your Workato Customer Success Manager.
In HashiCorp Vault:
- HashiCorp Vault Key-value (KV) secrets engine version 1 or 2.
- An account with AppRole auth method (opens new window) enabled.
- One or more AppRole (opens new window)s configured.
# Step 1: Select the scope for secrets management
Navigate to Settings > Secrets management.
In Scope, select the option “Set up secrets management for the entire workspace”.
# Step 2: Select the secrets manager
Continuing from the previous step, in the field In the Which secrets manager do you want to use?, select HashiCorp Vault.
# Step 3: Configure the following fields in Workato
Connect to HashiCorp Vault
- Connection name
- Name your HashiCorp Vault connection.
- Connection type
- If you want to connect using an on-premise group, select the group name from the picklist. Otherwise, to use a direct connection, select Cloud.
- Authentication type
- Select AppRole from the dropdown.
- Vault URL
- Enter the Vault URL of your Hashicorp Vault instance. It should follow this form
https://<instance_name>.<company_name>.com:123
.instance_name
The name of your HashiCorp Vault instance.
company_name
The name of your organization.
Namespace
Optional. The name of the namespace that contains the secret(s) you plan to use in Workato. Namespaces (opens new window) are a set of features that enable you to define granular control and secrets management within your organization.
In our example, we grant Workato access to the
admin/HR
namespace.
- AppRole name
- The AppRole you plan to use. An AppRole is a set of Vault policies and login constraints that determines which secrets you can access.
# Step 4: Obtain the AppRole ID and AppRole Secret ID from your HashiCorp Vault instance
AppRole is a login credential split into two parts- the AppRole ID and AppRole Secret ID. You must obtain both to authenticate to Workato. The AppRole ID can be considered similar to a username- its value remains constant and associated with its corresponding AppRole. On the contrary, the AppRole Secret ID is similar to a password or unique key and you can prompt HashiCorp Vault to refresh this credential, if needed.
In HashiCorp Vault click >_ to open the control panel.
Open the control panel
Enter the following command:
vault read auth/<approle_name>/role/<role_name>/role-id
approle_name
The AppRole you have configured in HashiCorp Vault.
role_name
The name of the role (Workato) you plan to connect to.
Example:
vault read auth/workato_approle/role/workato/role-id
HashiCorp Vault returns the AppRole ID unique to your AppRole:
Key Value
role_id 12a3bc45-6de7-8910-11fg-h4ij12XXXXXX
Copy and paste this value into the AppRole ID field in Workato.
Obtain the AppRole Secret ID by entering the following command to the control panel in HashiCorp Vault:
vault write -force auth/<approle_name>/role/<role_name>/secret-id
Example:
vault write -force auth/workato_approle/role/workato/secret-id
HashiCorp Vault generates an AppRole Secret ID for your AppRole:
Key Value
secret_id ed0a642f-2acf-c2da-232f-1b2130XXXXXX
secret_id_accessor a240a31f-270a-4765-64bd-94ba1fXXXXXX
Copy and paste the secret_id
value into the AppRole Secret ID field in Workato.
Workato displays the following message when you connect successfully.
Connection successful
FURTHER READING
Last updated: 1/2/2024, 7:18:05 PM
