# Recipe Lifecycle Management
GLOSSARY
Manifest: A container of different assets, including recipes, lookup tables, connections, and more.
Package: The build of a manifest. Contains the source code of each asset within a manifest. It includes the latest version of the asset available when the package was created.
# Quick reference
Type | Resource | Description |
GET | /api/export_manifests/folder_assets | View assets in a folder. |
POST | api/export_manifests | Create an export manifest. |
PUT | api/export_manifests/:id | Update an export manifest. |
GET | api/export_manifests/:id | View an export manifest. |
DELETE | /api/export_manifests/:id | Delete an export manifest. |
POST | /api/packages/export/:manifest_id | Export package based on a manifest. |
POST | /api/packages/import/:folder_id | Import package into a folder. |
GET | /api/packages/:id | Get package by ID. |
GET | /api/packages/:id/download | Download a package. |
# View assets in a folder
View assets in a folder. You can use this endpoint to help you create or update an export manifest.
GET /api/export_manifests/folder_assets
# URL parameters
Name | Type | Description |
folder_id | integer optional | The ID of the folder containing the asset. Defaults to the root folder. |
include_test_cases | boolean optional | Includes test cases from the list of assets. Defaults to false. |
include_data | boolean optional | Includes data from the list of assets. Defaults to false. |
# Sample request
curl -X GET 'https://www.workato.com/api/export_manifests?folder_id=423' \
# Response
"result": {
"assets": [
"id": 12,
"name": "Copy of Recipeops",
"type": "recipe",
"version": 1,
"folder": "",
"absolute_path": "All projects",
"root_folder": false,
"unreachable": false,
"zip_name": "copy_of_recipeops.recipe.json",
"checked": true
# Create an export manifest
POST /api/export_manifests
# Payload
name | string required | Name of the new manifest. |
assets | object required | Dependent assets. |
id | integer required | ID of the dependency. |
type | string required | Type of dependent asset. |
checked | boolean optional | Determines if the asset is included in the manifest. Defaults to true . |
version | integer optional | The version of the asset. Defaults to the latest version. |
folder | string optional | The folder that contains the asset. Defaults to "" . |
absolute_path | string optional | The absolute path of the asset. Defaults to root folder. |
root_folder | boolean optional | Name root folder. Defaults to false . |
unreachable | boolean optional | Whether the asset is unreachable. Defaults to false . |
zip_name | string optional | Name in the exported zip file. By default, Workato auto-generates a name with this structure: asset_#{index}.#{type}.json . |
include_test_cases | boolean optional | Whether the manifest includes test cases or not. Defaults to false . |
auto_generate_assets | boolean optional | Auto-generates assets from a folder. Defaults to false . |
include_test_cases | boolean optional | This parameter includes test cases from automatic asset generation. Defaults to false . |
include_data | boolean optional | This parameter includes data from automatic asset generation. Defaults to false . |
# Sample request
curl -X POST 'https://www.workato.com/api/export_manifests' \
-d '{
"export_manifest": {
"name": "Test Manifest",
"assets": [
"id": 12,
"type": "recipe",
"version": 1,
"folder": "",
"checked": true
"folder_id": 112
# Response
"result": {
"id": 12,
"last_exported_at": null,
"created_at": "2023-02-27T02:44:59.447-08:00",
"updated_at": "2023-02-27T02:44:59.447-08:00",
"deleted_at": null,
"project_path": "Folder 1",
"status": "working"
# Auto-generate assets
If you plan for Workato to auto-generate your assets, you can pass the parameter auto_generate_assets
into the payload of the request. You must specify the folder_id
you plan to have auto-generated. You can also choose to include test cases and data by adding the include_test_cases
and include_data
parameters. Note that test cases and data are excluded by default.
Additionally, you can include auto_run
in the payload to generate the package automatically.
# Sample request
-d '{
"folder_id": 112,
"auto_generate_assets": true,
"include_test_cases": true,
"include_data": true,
"auto_run": true
# Response
"result": {
"id": 12,
"deleted_at": null,
"status": "working"
# Possible statuses
Status | Definition |
working | Active. |
archived | Deleted. |
# Update an export manifest
PUT /api/export_manifests/:id
# URL parameters
id | integer string | The ID of the dependency. |
# Payload
Update the properties contained in assets[]
to replace the assets previously defined.
name | string optional | Name of the manifest. Update this value to change the manifest name. Defaults to previous name. |
# Sample request
curl -X PUT 'https://www.workato.com/api/export_manifests/12' \
-d '{
"assets": [
"id": 12,
"type": "recipe",
"version": 1,
"folder": "",
"checked": true
"folder_id": 112
# Response
"result": {
"id": 12,
"deleted_at": null,
"status": "working"
and include_data
# Sample request
-d '{
"folder_id": 112,
"auto_run": true
# Response
"result": {
"id": 12,
"deleted_at": null,
"status": "working"
# View an export manifest
GET /api/export_manifests/:id
# URL parameters
# Sample request
curl -X GET 'https://www.workato.com/api/export_manifests/12' \
# Response
"result": {
"id": 12,
"deleted_at": null,
"status": "working"
# Delete an export manifest
DELETE /api/export_manifests/:id
# URL parameters
id | string required | Export manifest ID. |
# Sample request
curl -X DELETE 'https://www.workato.com/api/export_manifests/12' \
# Response
"result": {
"success": true,
"status": "destroyed"
# Export a package based on a manifest
Export a package based on a manifest.
ENDPOINT PRIVILEGES ALSO PROVIDE ACCESS TO ASSETS
When you provide an API client with privileges to this endpoint, the API client is also granted the ability to view other assets like recipes, lookup tables, Event topics, and message templates by examining the resulting zip file.
POST /api/packages/export/:id
This is an asynchronous request. Use GET package by ID endpoint to get details of the exported package.
# URL parameters
# Sample request
curl -X POST 'https://www.workato.com/api/packages/export/<manifest_id>' \
# Response
"id":242,
"operation_type":"export",
"status":"completed",
"export_manifest_id":3,
"download_url":"https://www.workato-staging-assets.com/packages/zip_files/000/000/242/original/exportdemo.zip"
# Import a package into a folder
Import a package (zip file) into a folder.
When you provide an API client with privileges to this endpoint, it also grants the ability to create or update other assets like recipes, lookup tables, Event topics, and message templates through importing packages.
POST /api/packages/import/:id
This is an asynchronous request. Use GET package by ID endpoint to get details of the imported the package.
The input (zip file) is a application/octet-stream
payload containing package content. URL parameter restart_recipes must be true
if the running recipes need to be restarted upon import.
# URL parameters
id | string required | Folder ID. |
restart_recipes | boolean optional | Value must be true to allow the restarting of running recipes during import. Packages cannot be imported if there are running recipes and this parameter equals false or is not provided. |
# Sample request
curl -X POST 'https://www.workato.com/api/packages/import/<folder_id>?restart_recipes=true' \
-H 'Content-Type: application/octet-stream' \
--data-binary @'path/to/local/file.zip'
# Response
"id":251,
"operation_type":"import",
"download_url":"https://www.workato-staging-assets,com/packages/zip_files/000/000/242/original/exportdemo.zip"
# Get package by ID
Get details of an imported or exported package.
GET /api/packages/:id
# URL parameters
id | string required | Package ID. |
# Sample request
curl -X GET 'https://www.workato.com/api/packages/<package_id>' \
# Response
- This shows the response from the retrieval of a completed export manifest.
"id":242,
- This shows the response from the retrieval of a failed export manifest
"id":242,
"status":"failed",
"error":"error_message",
"export_manifest_id":4,
"download_url":"null"
- This shows the response from the retrieval of a completed import.
NOTE
For any completed import, it is important to also check each recipe's import_result. Learn more about the possible import_result values.
"id":242,
"status":"completed",,
"download_url":"https://www.workato-staging-assets,com/packages/zip_files/000/000/242/original/importdemo.zip",
"recipe_status":[
"id": 12345,
"import_result": "no_update_or_update_without_restart"
"id": 12346,
"import_result": "restarted"
"id": 12347,
"import_result": "stopped"
- This shows the response from the retrieval of a failed import.
NOTE
For any failed import, not all recipes may be returned in recipe_status
as they may not have been updated before the import failed. Learn more about the possible import_result values.
"id":242,
"recipe_status":[
"id": 12345,
"id": 12346,
"id": 12347,
# Recipe import_result values
There are a total of 6 possible results:
- This indicates no restart was needed for the recipe. Either recipe could be updated without it or no update was made. Successful importnot_found
- Unexpected error when recipe cannot be found. Should not often be seen. Import has failed with no update to recipe.stop_failed
- For recipes that need to be restarted, we attempt to stop the recipe. This state indicates we could not stop the recipe. Import has failed with no update to recipe.stopped
- Workato stopped the recipe but recipe was not restarted due to errors in the recipe. Import has failed with recipe updated but not restartedrestart_failed
- Workato attempted to restart recipe but failed to do so. Import has failed with recipe updated but not restartedrestarted
- Workato successfully restarted recipe after update. Successful import
# Download package
Downloads a package.
GET /api/packages/:id/download
# URL parameters
# Sample request
curl -L -X GET 'https://www.workato.com/api/packages/<package_id>/download' \
Follow redirects in cURL
Use the -L
flag to follow redirect paths.
# Response
If successful, you will be redirected to the package content. Returns 404
if package not found or doesn't have content.
Last updated: 4/5/2024, 11:22:40 PM
