# Environment properties
Use the endpoints below to manage environment properties programmatically.
# Quick reference
Type | Resource | Description |
GET | /api/properties | Lists environment properties that matches a prefix. |
POST | /api/properties | Upserts environment properties. |
# List properties by prefix
Returns a list of environment properties belonging to a customer that matches a prefix. For example, if the prefix provided is salesforce_sync.
, any environment property with a name beginning with 'salesforce_sync.' will be returned.
GET /api/properties
# Parameters
Name | Type | Description |
prefix | string required | Return properties with the given prefix. E.g: salesforce_sync. . |
# Sample request
curl -X GET 'https://www.workato.com/api/properties?prefix=salesforce_sync.' \
# Response
"salesforce_sync.object_name": "Account",
"salesforce_sync.object_field": "Id"
# Upsert property
Upserts environment properties. Matches by the names of the properties provided in the request.
POST /api/properties
# Payload
properties | Hash required | Contains the names and values of the properties to upsert. |
# Sample request
curl -X POST https://www.workato.com/api/properties \
-d '{ "properties": { "zendesk.object": "Ticket", "zendesk.key": "ticket_id" }}'
# Response
"success": true
Last updated: 4/25/2024, 5:58:27 PM
