# View test case run results
When Workato finishes running a test job, you receive a notification with the test case run results.
The test case run results modal contains the following information about each test case that was executed.
  • Recipe name
  • Test case name
  • Test case run result (passed/failed)
  • Check that failed (if any)
  • Link to a job for a test case run
# If the test case has no checks
The job run result is the same as the test case run result.
# Test case run jobs
In addition to viewing test case run results after a test case run completes, you can access all test case run results at the recipe level on the Jobs page.
Job pageSelect a test case run job from the list
# Test case job metadata
The Jobs page for each test case run contains the following information.
Job resultView test case run results
  • Steps that were mocked
  • Steps that had checks
    • For each check
      • Check data
      • Check result
  • Test case name and link
    • If the test case was deleted, Workato only displays the name of the deleted test.
Last updated: 5/25/2023, 4:50:47 PM
