# New record trigger
This trigger runs when a new record is created in a data table.
# Input fields
Choose a data table
Select a data table to search for new records.
When first started, this recipe should pick up events from
Get new records starting at a specific date/time. If you leave this field empty, the default condition is to retrieve new records from one hour ago. You cannot change this value after you run or test the recipe.
# Trigger conditions
You can use trigger conditions to filter out only the new records that are important to your workflow.
Change ID
The ID number that corresponds to the change in the data table.
Change time
The date and time the new record was added to the data table.
Record
Includes all fields from the object. This includes the following columns Workato auto-generates and additional columns you customize in your data table.
Record ID
The unique ID of the record.
Created at
The creation time of the record.
Updated at
The last edit time of the record.
Last updated: 2/20/2024, 7:05:48 PM
