# Delete record
Deletes a record from the specified data table.
# Input fields
Choose a data table
Select a data table where to make changes.
Record ID
The ID of the record you plan to delete. Workato automatically generates a unique ID for each record in a data table. Obtain the Record ID by viewing the Record ID column in the data table; the Record ID column is hidden by default.
Success
A boolean (true/false) value reporting whether the record was deleted successfully.
Last updated: 2/20/2024, 7:05:48 PM
