# SAP action: Call BAPI
Use this action to run BAPIs (Business Application Programming Interfaces) in an SAP system.
REMOTE FUNCTION CALLS: BAPIS AND RFMS
Remote function calls enable you to run both BAPIs and RFMs (Remote-Enabled Function Modules) within an SAP system. BAPIs are distinct from RFMs in the following ways:
BAPIs are standardized interfaces to SAP business objects, while RFMs are less standardized and can be multi-step processes.
In BAPIs, error messages or warnings are presented in a structured and clear manner within the response, unlike RFMs.
BAPIs generally don't perform immediate commits to an SAP system. This allows you to make a series of actions within a single transaction. You can commit these changes to the SAP system collectively or roll them back if errors occur.
Previously, you could invoke BAPIs using our Call remote function module action. However, this approach is limited when calling BAPIs: Even when a BAPI operation in the SAP system failed, Workato considered the action successful because the call itself succeeded. This meant that you had to include conditional logic ("if" steps) in your recipes to identify errors based on the response from SAP.
Conversely, the Call BAPI action leverages the standardized error message structure present in BAPIs to raise errors when a BAPI execution encounters issues automatically. It also highlights the validation errors detected by the SAP system and returns them to Workato. This eliminates the need to build recipe steps to check the SAP system for errors, streamlining recipe logic.
The Call BAPI action (right) reduces recipe steps and streamlines logic
Use this action with our existing Begin transaction and End transaction actions to run multiple RFMs in a single logical unit of work. This allows you to commit (or roll back) the entire sequence at the end of the transaction.
See How to run BAPIs in a transaction for the example flow.
# Input fields
BAPI description
Give this step a human-readable description, which will show up in the recipe step. This input does not affect the BAPI execution. For example, Create sales order.
BAPI name
Provide the exact name of the BAPI you plan to use. This input is case-sensitive.
Transaction ID
Provide the transaction ID from the output of the Begin transaction action. If this is mapped, Force auto commit is disabled.
Force auto-commit
Some BAPIs do not commit the changes by default. Select Yes if you plan to force the RFM to commit using the RFC
BAPI_TRANSACTION_COMMIT
. If the RFM fails, the RFCBAPI_TRANSACTION_ROLLBACK
is invoked. Select No if you plan to let the RFM commit on its own. IfBAPI_TRANSACTION_COMMIT
is not called within the RFM code, data is not committed to the database.Timeout
Configure the timeout for this call to up to 30 minutes. If you select 30 minutes, you cannot run this RFC in a transaction.
# Validation errors
If the following return types are included in the response, Workato raises an error:
Return type | Description |
A | Termination message (abort) |
E | Error message |
# How to run BAPIs in a transaction
Some BAPIs may need you to execute a BAPI_TRANSACTION_COMMIT
to commit the work into your SAP application. You can do so using the Force auto commit input or by running the BAPI in a transaction.
Add a Begin transaction action where you plan your sequence of BAPIs to start.
Add one or more BAPIs using the Call BAPI action. Map the output datapill Transaction ID from the Begin transaction action to the Transaction ID field. Configure other fields as necessary.
Add an End transaction action at the end of your desired sequence of BAPI calls. Map the output datapill Transaction ID from the Begin transaction action to the Transaction ID input field and select Commit work to save this entire sequence to your SAP application when the job execution reaches this step.
Wrap the Call BAPI action in a Monitor for errors block. This allows you to add an End transaction action with Roll back changes selected, enabling you to roll back the transaction if any of the steps face errors when you run your recipe.
Last updated: 8/15/2023, 4:01:22 PM
