# PostgreSQL - Run custom SQL action
# Run custom SQL
This action lets you send a SQL string to the PostgreSQL instance to be executed. It can be used to execute Data Manipulation Language (DML) statements like INSERT, UPDATE, SELECT and DELETE, as well as Data Definition Language (DDL) commands, like CREATE, ALTER and DROP.
Unlike Select rows using custom SQL, this action is not optimized for easy configuration. For SELECT statements with large number of columns, use that action instead.
This action requires a connection using OPA version 2.4.3 or newer.
Run custom SQL action Run custom SQL action
# Input fields
Input field Description
SQL
This field is required. Provide a valid SQL string to be executed. This SQL string will be executed in your PostgreSQL instance.
If multiple SQL statements are provided, all of them will be executed. However, only results from the last statement will be returned. Make sure each statement is separated by a ; character.
You can map datapills here to execute dynamically changing SQL statements. Remember to wrap datapills in quotes ('').
Output fields
Use this input to describe the columns that you are expecting from your SQL statement.
If you do not expect any return values or do not need any, you may ignore this input field.
# Output fields
Rows
List of rows returned from the SQL execution. The fields in this list are defined by the Output fields input field.
If left blank, this row will be available in the datatree as an array datapill.
Rows affected
This is an integer value indicating the number of rows inserted/updated/deleted from the SQL string.
When executing SELECT statements, this will return nil.
When executing a DDL (for example, creating a table), the value 0 will be returned.
# Limitations
There is a size limit of 50000 rows when your custom SQL statement returns data.
Last updated: 4/7/2021, 4:36:34 AM
