# Oracle E-Business Suite
Oracle's E-Business Suite (opens new window) (also known as Applications/Apps or EB-Suite/EBS), is a collection of enterprise resource planning (ERP), customer relationship management (CRM), and supply-chain management (SCM) computer applications that enables organizations of any size to operate and perform effectively.
# How to connect to Oracle E-Business Suite on Workato
# Prerequisites
Install Oracle E-Business Suite Integrated SOA Gateway (opens new window)
In the Oracle EBS, deploy User PL/SQL REST service (internal name: FND_USER_PKG) with name “user”. Below are the steps to install PL/SQL REST service
a. Login to Oracle EBS
b. From the main menu, select Integrated SOA Gateway > Integration Repository
Oracle Applications home page
c. Select Search
Select Search
d. Search for interface name "user" and select the service with internal name FND_USER_PKG
Locate FND_USER_PKG
e. Go to the REST Web Services tab. Enter the service name as "user" and select Deploy.
Locate the REST web services and enter "user"
# Establishing the connection on Workato
Create the Oracle EBS connection from within the recipe Connections tab, or from the account connections page (opens new window):
To create the connection, select Oracle E-Business Suite, fill in the fields required, and click Connect. At this point, Workato will make a simple “hello world” test to your Oracle EBS instance, using the REST service specified in User service name above.
If all goes well, you should get a green success message displayed next to the button.
Creating new Oracle E-Business Suite connection
Fields are as follows:
- Connection name:
Use something that identifies the specific Oracle EBS instance, for example, “HR Sandbox”.
- On-prem secure agent:
If your Oracle EBS instance is not accessible directly from the Internet, Workato will need to connect to it via an on-premise agent. Select the appropriate, active on-premise agent that has network access to this Oracle EBS instance.
- Instance URL:
The base URL where the REST services enabled on your Oracle SOA gateway can be accessed.
- Username:
The username that Workato will use to access the REST services on your Oracle SOA gateway.
- Password:
Corresponding password for the above username.
- User service name:
This is used only to test connectivity.
Last updated: 11/22/2022, 1:48:49 PM
