# Facebook Lead Ads
Facebook Lead Ads (opens new window) is a targeted advertising tool that allows businesses to collect lead information directly through ads, using forms that auto-populate with a user's Facebook contact details. You can use Facebook Lead Ads to efficiently capture leads, enhance your marketing campaigns, and drive customer engagement.
# API version
Workato's Facebook Lead Ads connector currently uses version v18.0 of the Facebook Marketing API (opens new window).
# Connection setup
Complete the following steps to create a Facebook Lead Ads connection in Workato.
Enter a Connection name to label your Facebook Lead Ads account within Workato.
Facebook Lead Ads connectionLabel your connection
Click Connect to open Facebook's login window.
Enter your credentials in the Facebook login window to authenticate your account.
Facebook loginFacebook login window
Review the permissions that Workato requests to manage your Lead Ads.
Facebook permissionsReview permissions
Click Continue to approve the connection permissions and complete the setup.
# Troubleshooting
If you have connected your Facebook account, given the relevant pages access and still can't trigger the recipe despite new leads being added -- utilize this tool (opens new window) to help with debugging the setup. You can select the relevant page and form and see if the Workato App has been successfully subscribed and even send a test webhook lead to check.
If the Workato application isn't subscribed correctly, the likely issue is that it needs be explicitly provided CRM access (opens new window) within Meta business manager.
We provide a step by step guide to the same as follows:
Setup a New leads trigger, start the recipe.
Go to Meta Business Suite (opens new window) -> Select your business in the drop-down -> Click the Settings icon -> Integrations -> Leads access
Go to CRMs tab and click on assign CRMs. Once you have started the recipe, Workato's OAuth app should be listed in the select options.
Assign Workato's App to CRMAssign CRM access to Workato's App
Now the OAuth app should be listed in the Facebook leads testing tool (opens new window), and the recipe should receive events when leads are created.
Lead Ads testing toolVerify the configuration in the lead ads testing tool
Last updated: 3/21/2024, 7:57:56 AM
