# Stop On-prem Agent
An on-prem agent process is typically stopped through a SIGTERM
. To send this signal to an agent you can:
- use the shutdown script (
./bin/shutdown.sh
) that comes with the on-prem agent, - or run
kill -s TERM
command on running agent.
Agent performs graceful shutdown by itself. This helps to terminate a running on-prem agent safely without disrupting any pending requests and avoids recipe job failures or data loss. The default shutdown timeout is set to 30 seconds.
# How does it work?
We recommend disabling the on-prem agent first, to prevent any further actions to be routed to this OPA. This can be done through the on-prem page or Developer API. To prevent disruption to your recipes, ensure that there is an active backup on-prem agent in the group.
Initiate a graceful shutdown by executing the shutdown script.
./shutdown.sh
By default OPA doesn't create PID file during startup. When you will get an error saying that pid file is not found, make sure that you start on-prem agent with the following option:
./run.sh --pid-file=/var/run/workato-agent/workato-agent.pid
and run the shutdown script with the same parameter:
./shutdown.sh --pid-file=/var/run/workato-agent/workato-agent.pid
The script will send SIGTERM
to gracefully terminate the agent process.
The agent will kill itself after the configured timeout if shutdown hasn't finished gracefully.
# Usage options
./shutdown.sh [args…]
# Examples
./shutdown.sh
./shutdown.sh --pid-file=/var/run/workato-agent/workato-agent.pid --pid-file-purge
./shutdown.sh --kill-signal=TERM
./shutdown.sh --help
# Optional arguments
Argument | Description |
--pid-file | Path to the pid file, which contains on-prem agent process id. Default: /var/run/workato-agent/workato-agent.pid |
--pid-file-purge | Purge PID file before exit. |
--kill-signal | Signal to use. Default: TERM |
--help | Display help list of all arguments, similar to this table. |
Last updated: 11/3/2023, 9:36:21 AM
